LabWindows/CVI
How can I draw a line/arrow on the UIR in CVI (Decoration?)?
Is there an easy way to do this without using a picture?  I would like to be able to draw a line/arrow and rotate it to point at specific items in the UIR.
(3,821 Views)
I think the easiest way to do this is to create a small canvas, set the background to transparant and draw your arrow using the CanvasDrawPoint function. The code below should draw you a nice arrow (make sure the canvas is large enough).
 SetCtrlAttribute (pnl, PNL_CANVAS, ATTR_PICT_BGCOLOR, VAL_TRANSPARENT);
 CanvasDrawLine (pnl, PNL_CANVAS, MakePoint (0, 8), MakePoint (30, 8));
 CanvasDrawLine (pnl, PNL_CANVAS, MakePoint (23, 1), MakePoint (30, 8));
 CanvasDrawLine (pnl, PNL_CANVAS, MakePoint (23, 15), MakePoint (30, 8));
I think it doesn't take too much time to figure out which coordinates to use to make the arrow point to another direction...
Success,
Wim
Message Edited by Wim S on 08-22-2006 02:20 PM
(3,801 Views)
I'm not sure this will meet your rotating requirements, but also check out this thread....
http://forums.ni.com/ni/board/message?board.id=180&message.id=24232#M24232
(3,788 Views)
