LabWindows/CVI
How can I access the XML document in memory?
I've created an XML document referenced by the handle "doc". I would like to access the pointer to this XML doc so that it can be transmitted to a host computer.
The only way I have found to do this is to use CVIXMLSaveDocument() to save "doc" to a file, and then immediately read it back into a string. Is there a way I can access "doc" as a char[ ] directly in memory without doing all the file i/o procewssing?
    CVIXMLDocument doc = 0;
    CVIXMLNewDocument("event", &doc);
    CVIXMLGetRootElement(doc, &elem1);
    CVIXMLSaveDocument(doc, 1, XML_FILE_PATH);
(3,679 Views)
While the CVIXML API does not provide a function for this, the underlying MSXML API lets one do this. Try the following code which loads a XML document and gets the XML as string. This should also work with XML that you programmatically create without saving to disk - just get the MSXML document handle and call MSXML_IXMLDOMDocumentGetxml.
#include <cvixml.h>
void main(void)
 char *xml;
 MSXMLObj_IXMLDOMDocument hDoc;
 CVIXMLDocument doc;
CVIXMLLoadDocument("c:\\temp\\test.xml", &doc);
 CVIXMLGetDocumentActiveXHandle(doc, &hDoc);
 MSXML_IXMLDOMDocumentGetxml(hDoc, 0, &xml);
(3,657 Views)
Thanks, Mohan.
That was what I was looking for.
Doug
(3,648 Views)
