LabWindows/CVI
How CVI runs applications without exe ?
I wonder about the CVI mechanism, how does it run applications when there is
no *.exe file of the application yet (when I select 'Run Project' form the
project window menu SHIFT+F5). Could it be that it runs the application as
if it was an interpreter ?
(3,552 Views)
Interesting question. I dont know the answer but here are some suggestions.
1) It builds the exe and saves it to the temp directory, then runs it
2) It builds the exe into memory and runs from there.
3) Builds some object code and uses the RTE to execute.
There are a lot of IDEs around so this is probably a commom task.
Anyone know the right answer.
Kevin Kent
(3,552 Views)
