LabWindows/CVI
HWND handle from ATTR_SYSTEM_WINDOW_HANDLE
What type of variable hWnd do i have to define when using the GetPanelAttribute
IS it a
int hWnd
and use in my application function as typed casted into (HWND)
or
HWND hWnd
and type cast it to (int*) hWnd for the above GetPanelAttribute function
Further, I am trying to display images captured by CCD camera. I have used the C codes that come with the camera...The problem is the image is supposed to be displayed on the panel that I have drawn using CVI user interface editor...and after getting and pssing the HWND handle to it. But no image was seen. But when i move/close a dialog box which was programmed to appear, I can see the image at the position previously covered by the dialog box. However, this image did
not stay visible for long. I wonder if there is some problem with the HWND handle or do I need to actively 'refresh' the panel or make the panel transparent?
Thanks for ur time and attention.
william
(3,291 Views)
I want exanctly the same. Do you find any solution for your problem??
(2,701 Views)
