LabWindows/CVI
HP5183A command
I am working on some code that used an HP signal generator which I believe is now obsolote. The code is writing a command to the signal generator to shut the power off using this command format
ViStatus _VI_FUNC hp836xx_writeInstrData (ViSession instrumentHandle, ViString writeBuffer);
the actual command used
hp836xx_writeInstrData (AGE83630_Handle, "pow:stat 1");
I am looking for the similar command from the HP5183A signal generator (ivirfsiggen.h and ivirfsiggne.fp files).
(3,297 Views)
Nevermind. I found it but don't know how to remove this thread.
It's
IviRFSigGen_ConfigureOutputEnabled (HP5183A_Handle2, VI_TRUE);
(3,292 Views)
Hello AEM,
No worries about the thread.  It just means that if anyone has a similar question in the future you saved them some time!
John B.
(3,269 Views)
