LabWindows/CVI
HP34401A problem
Currently using HP34401A driver and use the example code to display the result of the reading.
Data Type declaration of the variables according to the sample
            ViReal64  reading;
            ViChar    msgStr[256];
checkErr( hp34401a_Read (hp34401a, 5000, &reading));
sprintf (msgStr, "%f", reading);
so for it to display on the panel, i created
SetCtrlVal(panel,PANEL_STRING, msgStr);
not it shows the reading on the Panel as a string(correct me if I am wrong),
because I want to do a calculation first on the reading like I want to display it on float, how can i convert it as such, something like
floatvariable = reading/somevalue;
SetCtrlVal(panel,PANEL_STRING, floatvariable);
thanks
________________________________________________________________
Electronics Manufacturing Tester Forum
(3,492 Views)
Well the easiest way to do this is to create a numeric control on your panel and set it as an indicator for the double data type. Then you can simply do a:
    SetCtrlVal (panel, PANEL_NUMERIC, double_value_to_display);
JR
(3,482 Views)
Hello JR,
Thanks for your reply, I forgot, i have already the variable "reading" to work on.
(3,476 Views)
