LabWindows/CVI
HELP!!!! What happened to ctrl+v for paste?
This is going to sound crazy but here it goes. I just installed LabView 7.1 and LabWindows (7.0.0) no longer will paste with the ctrl+v comboniation, but if I right click and go to past or go to edit->paste it works just fine. All my other programs paste just fine, including the text I copied out of labwindows. I event tried reparing the install for labwindows but my ctrl-v did not come back. This is a VERY VERY VERY large problem for me because I am a habitual ctrl-c - ctrl-v user.
(3,094 Views)
Just a stab in the dark, but something hasn't assigned another shortcut action to the ctl v combination has it?
Don't have CVI 7 here to check if it allows shortcut definitions, but perhaps ctrl v is not performing some other, maybe unnoticed action?
Like I said, just a thought...
(3,094 Views)
This might just be the problem because it is as if the shortcut has just been reassigned but I can not figure out how/or if you can reassign shortcuts in labwindows.
(3,094 Views)
Matt,
To change shortcuts click on Options>>Change Shortcut Keys
Luis
(3,094 Views)
