LabWindows/CVI
Graph control and bitmap: out of memory and screen flicker
I use a old version of CVI to develop the application. I use graph to display a kind of image movement. So First I have a loop to use
PlotBitmap to display and DiscardBitmap to release the memory for each PlotBitmap, still I got out of memory error after a while and finnally crash the system. Then I combine PlotBitmap(with null file name) and SetCtrlBitmap, then the screen start to flicker (the ATTR_REFRESH_GRAPH is set to 0 and call RefreshGraph to refresh manually, the strange thing is that with only PlotBitmap, it doesn't flicker)
thanks,
Eric
(3,538 Views)
Hi Eric,
The likely reason that you are seeing a memory leak is that you need to delete the reference to the plot before the last image was added.  Each time you plot an image, a new plot is created in your control, so we need to use the DeleteGraphPlot function to clear the old reference.  This can be accomplished using something like this:
oldPlotHandle = PlotBitmap (panelHandle, PANEL_GRAPH1, x, y, width, height, fileName[]);
loop
    DeleteGraphPlot(panelHandel,PANEL_GRAPH1,oldPlotHandle,VAL_DELAYED_DRAW)
You shouldnt need to use DiscardBitMap(), since PlotBitmap does not create an image ID, only a plot handle.  hope this helps!
Al B.
Staff Software Engineer - TestStand
CTA/CLD
(3,505 Views)
Hi AI,
thank you for your reply.
Actually since the beginning the function DeleteGraphPlot is called to delete all plots for each loop (with the plothandle -1, besides plotbitmap, application also plot point and text). After application runs a while, it starts return -12 for function PlotBitmap from time to time. After checking the forum here, I decided to add DiscardBitmap() function. Any other suggestion?
Eric
(3,491 Views)
