LabWindows/CVI
GetFirstFile, GetNexFile - Internal process
How GetFirstFile determine the first file (whatever the search criteria) :
- by aplphabetic order ?
- by date ?
2 -
Does GetFirstFile create a list of file corresponding to the search criteria ?
Does GetNextFile only go through this list ?
3 -
What happens if, between a GetFirstFile call and a GetNextFile call, the list of file is deleted (for ex.) or modified ?
Can GetNextFile give a file name which does not exist any more ?
4 -
How to take into account a possible evolution oh the list of file between a GetFirstFile call and a GetNextFile call ?
Thanks for your help.
(3,621 Views)
I know only one:
it gets all the files by alphabetic
For all your problems the sample (samples\sdk\audio\sndplay) perhaps helps...
(3,617 Views)
1. The order of results returned by GetFirstFile depends on the platform. You will find this information in the following Knowledge Base :
- "Order of Results Returned by GetFirstFile and GetNextFile Functions":
http://digital.ni.com/public.nsf/websearch/CCDF9D76E197272F86256F78000269E3?OpenDocument
2. Indeed, GetFirstFile() create a list of files matching to the criteria that is used by the GetNextFile() function.
3. As a consequence, if a file is deleted after the call to the GetFirstFile() function, GetNextFile() can give the name of a deleted file.
4. To avoid this issue, you can use the GetFileAttrs(...) function after each call to GetNextFile(). This function will return -1 if the file no more exists.
Best regards.
Benjamin
NI France
(3,586 Views)
