LabWindows/CVI
Get name of a file
I have a full filename information (directory + file extension) and I would like to have only the filename without directory without extension. Is is possible with LabWindows
For instance,
I have c:\test\text1.txt and I would have text1
Message 1 of 8
(5,418 Views)
Yes, it's possible. You can use the function SplitPath from the utility library.
Message 2 of 8
(5,417 Views)
....edit time has expired, Smiley Sad
Yes, it's possible. You can use the function SplitPath from the utility library. This will give you the file name. In the next step, you can use FindPattern ( path_name, 0, -1, ".", 0, 1 ) to search for the dot., and using CopyString for copying the last few characters; the number of characters you need to copy is returned from FindPattern.
Message 3 of 8
(5,407 Views)
To exclude the extension you can do the following:
if ((nc = FindPattern (FileName, 0, -1, ".", 0, 0)) > 0) FileName[nc] = 0;
FindPattern is part of the Formatting and I/O Library
Edit: written while Wolfgang was giving the same response Smiley Wink
Message Edited by Roberto Bozzolo on 06-07-2010 12:33 PM
Message Edited by Roberto Bozzolo on 06-07-2010 12:34 PM
Message 4 of 8
(5,405 Views)
Roberto,
I find it better to use Wolfgang's syntax in FindPattern() to search backwards for the '.' that belongs to a file extension. Otherwise if you search forwards you might find some other '.' within the body of the file name.
JR
Message 5 of 8
(5,391 Views)
Smiley Surprised Oh my! Of course you're right!
That line came from an old app of mine I am updating these days: I will double check to correct all instances if this call in this direction.
Message 6 of 8
(5,359 Views)
SplitPath won't help to much, as far I can read from the documentation the file extension is kept in the outcome
Message 7 of 8
(3,632 Views)
You're right, that's why we suggested to use FindPattern to search for the rightmost dot and stop the filename there.
Message 8 of 8
(3,627 Views)
