LabWindows/CVI
Get data from STDIO window
Is it possible to read from the DOS stdio window in a console app? I'm looking for the result of a DOS batch command. Thanx.
(3,351 Views)
Maybe you can redirect output from your DOS commands to a physical file and read the file content.
A DOS command can create a new output file by adding "> filename" after the command (such as "Dir > output.txt") and append to an existing file by using ">>" instead of ">".
(3,351 Views)
