LabWindows/CVI
Get TS Step Name String from CVI
I would like to get the step name, in CVI, of the currently executing TS step. Using CVI 6.0 and TestStand 2.0.
partial code:
char *stepName;
error = TS_PropertyGetValString (testData->seqContextCVI, &errorInfo,"RunState.Step.Name", 0,&stepName );
An error is returned and the stepName is returned as "Un-initialized"
How do I get the StepName string?
(4,335 Views)
Hi joebae,
In TS 3.5 I have the RunState.NumStepsExecuted property. While executing the first step its value is 0, for the second step it is 1, etc. So you can use it directly as a step index (since index is zero-based). And it resets at the beginning of Setup, Main and Cleanup. To distinguish if TS is currently in Setup, Main or Cleanup you can use RunState.StepGroup. So you can use StepGroup together with NumStepsExecuted to get which step in which group is executing.
But, for the step name I could not find a direct solution either. Maybe you can locally in CVI store an array of step names. I know, it becomes a pain when you change a step name or order but that is the best I could find for now.
I will inform you if I can find a better solution.
S. Eren BALCI
IMESTEK
(4,321 Views)
Hi again joebae,
There is not a Name property in TS sequence context, but in TS help I saw Step.Name. Maybe you can access it through CVI directly.
So you can probably write the following as the lookup string:
RunState.Sequence.Setup/Main/Cleanup[RunState.NumStepsExecuted].Name
Hope this helps.
S. Eren BALCI
IMESTEK
(4,318 Views)
joebae,
The way you would want to access this is through the TestStand API ActiveX calls. You will need to get a reference to the current running step as described indexing from RunState.NumStepsExecuted, you will then need to use an API method to grab the name, I'm looking to see what the API call is for TestStand 2.0 and will post back here as soon as I find it.
Message Edited by Brandon V on 04-19-2007 01:52 PM
Brandon Vasquez | Software Engineer | Integration Services | National Instruments
(4,294 Views)
The API Method you are going to need to call is PropertyGetProperty with the PropertyID as Name in the PropertyObject class of the TestStand API.
(4,282 Views)
Thanks for the assistance
 I was able to find the solution in the Simple.c example from CVI 6.0
 In TS 2.0 CVI 6.0 more info is needed from the Seq to get the step name
// Declare variables
    CAObjHandle step = 0;
    CAObjHandle sequence = 0;
    int error = 0;
    long        StepIndex = 0;
    long        phaseIndex = 0;
    char *      stepName = 0;
     // Get The Step index into the program
    error = TS_SeqContextGetProperty (testData->seqContextCVI, &errorInfo,
                                        TS_SeqContextStepIndex, CAVT_LONG,
                                      &StepIndex);
    //Get the Seq Context SetUp, Main or Cleanup
                    &errorInfo, TS_SeqContextStepGroup,
                                    CAVT_LONG, &phaseIndex);
    // Get the OBJ handle to the Sequence
                    TS_SeqContextSequence,
                                   CAVT_OBJHANDLE, &sequence);
    // Get the Step Number
    error = TS_SequenceGetStep (sequence, &errorInfo, StepIndex,
                                       phaseIndex, &step);
    // Get Step name to of the Step
    error = TS_StepGetProperty (step, &errorInfo, TS_StepName,
                CAVT_CSTRING, &stepName);
 In TestStand 3.0 CVI *.0 it is very simple to get the Step and Step name
    char* stepName = 0;
// Get the step number as an Obj handle
    TS_SeqContextGetStep(testData->seqContextCVI, &errorInfo,&step);
// Get the name of the step from the Obj handle
    TS_StepGetName(step, &errorInfo, &stepName);
(4,256 Views)
