LabWindows/CVI
GenericMessagePopup causes error 17502 in TestStand
Using the standard CVI dll proto type adapter any attempts to use "GenericMessagePopup" in TestStand causes a GPF.
Any Ideas?
Steve
Message 1 of 15
(5,047 Views)
Hey Steve,
I tried to replicate the error here, and I was unable to get any errors using the "GenericMessagePopup" from CVI in TestStand.  Could you post a snippet of code that exhibits this behavior?
Pat P.
Software Engineer
Message 2 of 15
(5,018 Views)
This is it.... Doesn't get much simpler that this:
#include
"stdtst.h"
#include
"tsutil.h"
#include
"tsapi_utilities.h"
void
__declspec(dllexport) PassFail(tTestData * testData, tTestError * testError)
char buffer[256];
GenericMessagePopup (
"Test Panel", "Sample Project", "OK", "Quit", "",
buffer, 255, 0, VAL_GENERIC_POPUP_BTN1,
VAL_GENERIC_POPUP_BTN1, VAL_GENERIC_POPUP_BTN2);
return;
Some new information though:
The fault only occurs when multiple dlls are being loaded into TestStand. These dlls are a mix of CVI 6.0 and CVI 8.0.1. If I tell TestStand to load the step that calls this code dynamically the fault disappears.
With the number of test sequences and test code; rebuilding all of the test code in 8.0.1 or modifying all of our test sequences is not going to be an acceptable work around.
Hopefully someone has some better ideas than this approach as a work around.
Thanks, Steve
Message 3 of 15
(5,008 Views)
Check the size of your buffer.  The error usually points to an array (buffer) overbound.
It is trying to place something larger than the size of the buffer (or array).
Message 4 of 15
(4,977 Views)
Why dont you just use the TestStand Message StepType?
Also, how are you filling buffer? Your code snippet just shows it declare then its used so its going to have grabbage in it.
Regards
Ray Farmer
Regards
Ray Farmer
Message 5 of 15
(4,950 Views)
Many people here have started using The TestStand Message StepType. Many have changed thier sequences to have TestStand load the step that calls this type of code dynamically which causes the fault to disappear. I'm presently rebuilding all of the process model code in CVI 8.0.1.
The buffer is of course filled by "GenericMessagePopup". I must not understand the question 😞
Upgrading to latest NI versions..... Sounds so simple!
Message 6 of 15
(4,951 Views)
No, my mistake, it the response buffer.
I think the only way is ti make sure your step is loaded dynamically and unloaded when completed.
and sometimes a bold move.
Regards
Ray Farmer
Regards
Ray Farmer
Message 7 of 15
(4,937 Views)
I thought it might be related to the buffer..  at least that's what the error code was in my past experience.
Upgrade???  now that's bold!  😮
Probably not necessary in this case 😉
Message 8 of 15
(4,928 Views)
You got to love that screen name "JoeLabView". That's right up there with "JoeTestEngineer". I wonder if there is a "JoeTestStand" out there. Maybe something has changed in TestStand in how it loads DLLs into memory and "JoeTestStand" is reluctant to join in on this thread.
Where is "JoeTestStand"? Smiley Very Happy
Message 9 of 15
(4,923 Views)
LOL!! 😄
Yeah... I always saw Ray Farmer as some sort of JoeTestStand...
The name's up for grab, though..  😉
Hey!!  Someone tried to copy my nick!! 😮  Some dude calling himself joeLabviewEngineer...  -wow-  😛
Message 10 of 15
(4,915 Views)
