LabWindows/CVI
Generating a output signal
I know this is a litte bit of a easy question. I am new with LabWindows and now I am at the part where I would like to generate a square wave signal. At the moment I can measure a DC signal at the output. I can als change the value but I am not able to measure my square wave signal.
I would like to ask if someone can send me an example code where I can see how a signal is produced and how I can generate it at the analog output from my analog-digital-card (SCB 68B).
    double SignalArray[512];
    TaskHandle taskHandle;
    float64 data;
    double phase=0.0;
            SquareWave (512, 2.0, 7.8125e-3, &phase, 50.0, SignalArray);
            PlotWaveform (Haupt, Haupt_GRAPH, SignalArray, 512, VAL_DOUBLE, 1.0, 0.0, 0.0, 1.0, VAL_THIN_LINE,
                                  VAL_EMPTY_SQUARE, VAL_SOLID, 1, VAL_RED);
            DAQmxCreateTask ("", &taskHandle);
            DAQmxCreateAOVoltageChan (taskHandle, "Dev1/ao0", "a0Channel", -10.0, 10.0, DAQmx_Val_Volts, "");
            DAQmxWriteAnalogF64 (taskHandle, 1, 1, 10.0, DAQmx_Val_GroupByChannel, &data, NULL, 0);
The problem is, in the interface I got the square signal but I do not know how I can get the data from the signal in my analog output. I know that the variable &data ist the key but I do not know how I can my square wave data in there. I think die data should be in "SignalArray".
It can also be that there is a easier way. I would like to know the basic behind this topic with a example code. I read a lot of liturature but I didn't find the anser to generate a signal (not a normal DC voltage) at the output.
I hope someone can help me.
Best Regards
(4,103 Views)
I suggest you to look at the examples installed with DAQmx: the closest to your scenario is ContGen-IntClk.cws then you can locate with the example finder (Help >> Search examples...) by browsing to Hardware input and output >> DAQmx >> Analog Generation >> Voltage. The example will show you how to prepare and write to the daq board the buffer and configure the board to generate the wave continuously.
(4,098 Views)
thank you very much. I will look at the example.
Best Regards
(4,078 Views)
