LabWindows/CVI
Generalized SVD
Hello NI-Community,
I am using LabWindows/CVI (I cannot check the version at the time I am writing this post.) for controling a DAQmx device. I would like to perform a generalized SVD with measured data. Unfortunately I cannot find this function in my libraries. Furthermore I could not find informations in the internet if an algorithm exits in a LabWindows version.
But I found the information that the generalized SVD exits as a VI in Labview. So is it really true that NI only provides an algorithm for Labview and not for LabWindows?
With kind regards,
Marcel
(4,780 Views)
Hi Marcel,
this really depends on the version of CVI you have... the base version comes without the Advanced Analysis Library which provides functions for SVD; however, this library is included only in the full version of CVI.
Depending oin the version of CVI the function is either called SVD or SVDEx (CVI 8 and later versions)
(4,767 Views)
Hi Wolfgang,
thank you for your reply. My LabWindows/CVI version is 2012 with an Advanced Analysis Library. I have the functions SVD, SVDEx and the complex alternative CxSVD, but unfortunately the calculations behind these functions are the standard SVD. The generalized SVD (GSVD) is a decomposition of two matrices. The SVDEx cannot calculate this decomposition.
On the following pages, I found informations, but only for Labview:
http://zone.ni.com/reference/en-XX/help/373123C-01/lvtextmath/msfunc_gsvd/
http://zone.ni.com/reference/de-XX/help/371361K-0113/gmath/general_svd_decomp/
It would be a bit depressing if only Labview have a GSVD because I always thought that there is also C-code behind a VI.
With kind regards,
Marcel
(4,761 Views)
