LabWindows/CVI
GUID of Matlab R2013a
Hello
I have to migrate the software of a test bench from an older pc to a newer one.
In the code there is also a part where Matlab is needed and therfore it is started as an ActiveX Object.
To start it you need the GUID (Globally Unique Identifier) of Matlab but as there is a newer version of matlab installed on the new pc it doesn't work.
Here is the Code :
HRESULT CVIFUNC MLApp_NewDIMLApp (const char *server, int supportMultithreading,
                                  LCID locale, int reserved,
                                  CAObjHandle *objectHandle)
    HRESULT __result = S_OK;
    GUID clsid = {0xA052DEB6, 0x24BF, 0x4425, 0xB4, 0xAE, 0xE8, 0xC5, 0x5D,
                  0x26, 0x45, 0x66};
    __result = CA_CreateObjectByClassIdEx (&clsid, server, &IID_IDispatch,
                                           supportMultithreading, locale,
                                           reserved, objectHandle);
    return __result;
I hope you can help me.
(4,431 Views)
Has anyone an idea ?
(4,376 Views)
Have you tried using the ActiveX Controller Wizard (Tools|Create ActiveX Controller...) to create a new interface module for the version of MATLAB you have?
Martin
Certified CVI Developer
(4,369 Views)
