LabWindows/CVI
GUI Localization Utility - Text Message Default Value
CVI 2015f1 GUI Localization Utility - using text message controls
Labels and titles all seem to localize properly,  however the Text Message default string content does not as it it remains in the default language at runtime.  Is this intentional?  If I have to instead programmatically set a string value for this type of control then text message content  must then be handled 'dynamically' rather than 'statically' for localization.  Is there another  workaround for the default message content?
(3,093 Views)
Dear Steve,
I was able to add a text message string and quickly create a new .lwl file (I went off a shipping example) and it converted over no problem. Are you sure everything in you .lwl file is in order?
(3,050 Views)
