LabWindows/CVI
GPIB system with 2 computers
I have this temporary situation where both me and a workmate are
working on the same system which uses several GPIB instruments.
I was thinking (havn't tried it yet) to connect another PC with a GPIB
controller connected on the same instruments cable. This way each one
of us can do his job without time sharing the system.
I presume there should be a problem as only one GPIB controller is
allowd.
Can it be done?
Even a partial solution will be acceptable. For example:
1) Both PCs are connected but only one of them will communicate on the
GPIB.
2) (less desirable). Both PCs are connected but one if them is
shut-off.
Rafi
(3,069 Views)
I am using a GPIB Enet/100 where both me and my co-worker can talk to
same test equipment at same time (for development). Look for these
boxes, they are cheap on used mkt.
vishi
> allowd.
> Can it be done?
> GPIB.
> shut-off.
> Thanks
> Rafi
(3,069 Views)
