LabWindows/CVI
GPF + InstallCtrlCallback?
I'm getting a GPF all of the sudden in a branch of a very mature project.  I've been getting it in the debugger, and the code breaks at RunUserInterface().
I managed to track down where/what is causing it, but I'm at a loss as to why.
In this new branch, I'm replacing the callback function of a table control on one panel.  I use InstallCtrlCallback to do so.  This works as it should.  Inside its new callback function, I call a function which does some NewCtrl (timer creation within the same thread) and then InstallCtrlCallback for the timer.  These are causing the GPF when I allow the function to return.
If I simply comment out the creation of those timers & callback installs, no more GPFs.  Why?!
(3,438 Views)
Hi ElectroLund
What version of LabWindows/CVI are you using?
Is it possible to get a smallest-reproducible-case working? I would be happy to run a simple bit of code that causes the error and test it on my end.
Mitchell Faltin
www.ni.com/support
(3,396 Views)
Thanks for your help.  Inexplicably, today I'm not seeing the issue.
I'll keep an eye on it and let you know if it returns.
(3,391 Views)
