LabWindows/CVI
For a Labwindows CVI application in console and graphical UI how to remove console
Dear community,
I am making Labwindows CVI application which need to be started as Graphical User Interface if there is no parameters and in Command Line (no UI) is there are some parameters.
So in the "BUILD" / "TARGET SETTING" menu, I set the "Create Console Application" item.
But when I launch the application with no parameter, I have a "console windows" that appear.
How would you do to avoid starting that "console window" or close it?
Thanks for your help.
Serge
(1,819 Views)
Hi Serge,
have a look at SetStdioPort and the other SetStdio-Functions in the Utility Library's Standard Input/Output Window class.
/* Nothing past this point should fail if the code is working as intended */
(1,779 Views)
