LabWindows/CVI
Finding Controls on a Panel
I am writing several configuration screens for various tests and I would
like to find/create a function that would find all the controls on a
page and one by one save them, this is easy enough, except I have no way
of knowing what type of control I have.
I plan on starting with the panel 1 and setting the active control ++
until I receive an error. As the UIR always maintains the controls from
1 up in a contiguos fashon. My problem is I need a function like
GetControlType so I know if I am dealing with a check box or a table.
Any Ideas??
(4,602 Views)
if you have a diferent label for each control and a table on your source code
that contain all labels with they respective type, than you can discover
the type using getControlAttribute - control Label text and so verifying
the table.
John Stuart wrote:
>I am writing several configuration screens for various tests and I would>like
to find/create a function that would find all the controls on a>page and
one by one save them, this is easy enough, except I have no way>of knowing
what type of control I have.>>I plan on starting with the panel 1 and setting
the active control ++>until I receive an error. As the UIR always maintains
the controls from>1 up in a contiguos fashon. My problem is I need a function
like>GetControlType so I know if I am deali
ng with a check box or a table.>>Any
Ideas??>>>
(4,602 Views)
According to CVI documentation the right way should be this one:
GetPanelAttribute (PANEL, ATTR_PANEL_FIRST_CTRL, &ctl);
// Find first control in the panel
while (TRUE) {
// Find control's style
GetCtrlAttribute (PANEL, ctl, ATTR_CTRL_STYLE, &style);
switch (style) {
case CTRL_NUMERIC:
// Your code to retrieve and save control's value
break;
// Other styles to control here
default:
// All styles not interesting: those ctls are simply skipped
break;
// Look for next control in the panel
GetCtrlAttribute (PANEL, ctl, ATTR_NEXT_CTRL, &ctl);
if (!ctl) break; // End of panel controls
Regards
Roberto
"John Stuart" ha scritto nel messaggio
news:3A65DB69.7B8348B0@cisco.com...
> Any Ideas??
(4,602 Views)
This is how I implemented it. Could you please tell me the location of this
information in the CVI Documentation. I found it by accident in the Help
file. I would prefer to find information like this in a printed manual so I
can read it offline.
STU
> while (TRUE) {
> switch (style) {
> case CTRL_NUMERIC:
> break;
> default:
skipped
> break;
> Regards
> Roberto
> > Any Ideas??
(4,602 Views)
Sorry, I too found these informations in the help files.
You can find some detail in the User Interface Reference Manual, but only a
little regarding the matter we are discussing about. I spent a lot of time
in temptative coding due to lack in the documentation, but found NI support
useful and ready to answer to my questions.
Roberto
(4,602 Views)
