LabWindows/CVI
FileSelectPopup
When selecting a file that already exists, it asks if i want to replace it?  What if i want to append to an existing file??  How do i get rid of that question or is there another function that i can call that will allow me to append to the file??
(3,606 Views)
This question is asked, depending on the parameter buttonLabel. If this function parameter is set to VAL_SELECT_BUTTON or VAL_LOAD_BUTTON, selecting an existing file will be allowed. Check the value, returned by the FileSelectPopup function to check if the user selected an existing file or a new file. If an existing file is selected, you can open the file and append new data to it.
Message Edited by Wim S on 09-13-2006 03:01 PM
(3,606 Views)
Thank you that did the trick...
(3,597 Views)
