LabWindows/CVI
FileSelectPopup at different languages
I need to open a FileSelectPopup at different languages (Germen, englisch
and french). How can I conform the panel to the selected language ? (CVI
5.0)
iSiTEC GmbH
Dipl.-Ing. Norbert Rieper
Stresemannstr. 46 / 0.10
27570 Bremerhaven
Tel: 0471 / 92234-31
Fax: 0471 / 92234-44
nrieper@isitec.de
(3,532 Views)
Sorry Norbert, I think there is no way to open the FileSelectPopup with a
different language. Some of the text strings in the popups are found in the
text files of the CVI runtime library ( for a windows PC at
\windows\system\cvirte\msgrt.txt) but not all.
Do you use windows? Then you can try to use the "GetOpenFileName" API from
windows. This should open an file select dialog in the actual windows
language. Maybe its helps
Stephan Gerhards
DATALOG Systeme zur Meßwerterfassung GmbH & Co. KG
Trompeterallee 110,
D-41189 Mönchengladbach
Tel.: +(49) 21 66/ 95 20 59
Fax: +(49) 21 66/ 95 20 20
e-mail: stephan.gerhards@ni.com
Norbert Rieper schrieb in im Newsbeitrag:
3976f4be@newsgroups.ni.com...
> 5.0)
> iSiTEC GmbH
> 27570 Bremerhaven
> nrieper@isitec.de
(3,532 Views)
