LabWindows/CVI
FileSelectPopup - Sorted results
Has anyone had success with sorting the files and directories displayed in the popup window resulting from a FileSelectPopup() call?  I suspect an indirect way to do this would be to set Windows defaults in Windows Explorer before running the application, but I am looking for a programmatic way to sort the query.
Message Edited by Ryykker on 08-30-2005 06:13 PM
(2,965 Views)
I do not think there is a way to do this apart from setting the windows defaults. There is also no file select popups I could find in the SDK. I did not find ant programmatic methods, but I am sure there should be, that's most propably the only solution, i.e. programatically set the windows defaults.
I might be wrong, but I looked long and hard.
Jattie van der Linde
Engineering Manager, Software & Automation
TEL Magnetic Solutions Ltd
(2,949 Views)
