LabWindows/CVI
FileSelectPopup - Error at cancel
hello,
I have a little problem with the fileselectpopup
I select a popup with the function
         FileSelectPopup( "c:\\Documents\\Axinia\\LabWindows-CVI\\Files","*.ini", "*.ini", "Select File", VAL_LOAD_BUTTON , 0, 0, 1, 0, buffer );
if I now, press cancel comes following error:
           NON-FATAL RUN-TIME ERROR:   "function.c", line 302, col 9, thread id 0x00000D2C:   Library function error (return value == -55 [0xffffffc9]). The index passed is out of range
can everybode told me how I prevent this?
thanks
(4,026 Views)
This is strange: I never have seen this error on FileSelectPopup. Can you experiment with different buttons (for example Select or Open button)?
Are you sure this error happens in that exact line? Column 9 is in the middle of the command name, it's not likely to refere to FileSelectPopup command. Could it be that you are not handling the VAL_NO_FILE_SELECTED return code and are trying to process a (possibly) empty 'buffer' variable? Executing the code step-by-step can be a useful mean of detecting where exactly the error arisea and what your code is doing: place a breakpoint on FileSelectPopup line and execute one instruction at a time by pressing F8 key.
Message Edited by Roberto Bozzolo on 04-29-2009 05:59 PM
(4,021 Views)
Axinia,
How large is your "buffer".  It looks to me as though you haven't allocated a buffer large enough to hold the filename.  Your char buffer should be MAX_PATHNAME_LEN (1024) bytes.
Greg
(4,016 Views)
@Roberto Bozzolo
I has already tried with different buttons. if I, for example, load it also clicks functioned. it does not function only if I cancel press.
yesterday I have already obeyed your advice already before I posted this problem. the buffer is filled correctly. and error is indicated in exactly this line at this point
@gavan
the buffer has in length of 1024 this I have also already tried
(3,979 Views)
To test if there is something wrong in your CVI installation, you could try executing some of the samples distributed with the product. There should be a popups.prj sample within samples\userint directory thet makes use of a FileSelectPopup: are you able to run it without errors?
(3,976 Views)
