LabWindows/CVI
FileBrowser does not show the detailed tree structure of the directories under the ROOT LEVEL STRING directory when control is not created in main.c (in the main() function)
Hello all,
I have created a filebrowser panel in my application. I am trying to load the filebrowser panel when the user clicks a menu option from my panel menu. On clicking a certain option, I will load the panel for the filebrowser, and perform the following set up calls -
FileBrowser_Create (handle, PROPANEL_FILEBROWSER, ROOT_LEVEL_STRING);
FileBrowser_SetAttribute (handle, PROPANEL_FILEBROWSER, ATTR_FILE_FILTER, ".pro");
DisplayPanel (handle);
The filebrowser panel does get successfully displayed but I do not get an exhaustive tree structure in the file tree window (Folders). All I see is the My computer level and the C drive below it. When I click on the C drive I can see the directories and files in the C drive inside the next tree panel (but here there are no options to expand the sub folders and check their contents). It would be nice if I could see all the folders and sub folders under My Computer in the first tree panel (Folders).
The strange part about this issue is that when I have the exact same code in a main() function where I specify the above code, I can successfully see all the tree structure as I would like to.
I hope I am being able to convey my problem to everyone.
Is this a known issue? Do I need to do something extra (Set Attribute to something special?)? Any work around suggestions?
Thank you so much!
Aparupa Guha (Babi)
GE
Aviation
Digital Systems
Development Equipment Software Lead
T 616 224 6457
3290 Patterson SE, Grand Rapids, MI 49512, U.S.A
(3,195 Views)
Hi Babi. I wasn't able to reproduce what you are seeing. I'm attaching a project that currently has the two calls in main() and placing them in the callback for the Show Tree button does not change its behavior at all.
Test Engineer - CTA
(3,167 Views)
