LabWindows/CVI
File path notation
I need to disply several file paths in the same panel. In order to reduce
panel size I would like to use the 'dotted' Windows notation like
'C:\WIND...\FILE.TXT and let the user display the full path in a separate
window. Is there a standard Windows function to obtain the reduced string
from the full path name?
TIA
Message 1 of 1
(3,146 Views)
