LabWindows/CVI
FieldPoint driver - file format does not match
I just installed version 4.0.1 of the Fieldpoint driver. Now when I start CVI (v 6.0 I get the following error:
Aborted load of object module "...FieldPoint.obj". The file format of
"...FiledPoint.obj" does not match that used by the current compatibility
mode.
The current CVI compatibility mode is set to Visual C/C++.
What can I do to fix this?
(3,118 Views)
We have seen a problem a couple of times where the installer sets the wrong compatibility mode of the FielPoint files. The fastest way to get this up and running is to run the FieldPoint installer again and select the right compatibility mode. Make sure that you don't select the "Install Every Sub-feature" for the driver and manually add the compatibility mode.
Let me know how this goes.
Juan Carlos
N.I.
(3,118 Views)
That did it. Thanks!
(3,118 Views)
