LabWindows/CVI
FTDI libMPSSE in LabWindows
Recently purchased FTDI cable C232HM-EDHSL-0, drivers installed OK automatically via Internet.  I’m trying to compile the libMPSSE I2C sample-static program under LabWindows CVI 2013 SP2.  I took heed of their FTDI knowledgebase article, except my version of CVI doesn’t have the VisualC/C++ compatibility choice under Build Options.  There is also some confusion about the several ftd2xx.lib files I find (but I’ve tried them all and get same error).  Compiles OK, but linking problem.
Typical linking error: Undefined symbol '_I2C_CloseChannel@4' referenced in "c:\Users\...\{my program}.obj".
windows, ftd2xx and libMPSSE headers present, ftd2xx.lib included in project
Any advice out there?
(3,037 Views)
Can you try compiling the program in a different development environment that does support VisualC/C++ such as Visual Studio? If you get the same linking error, then we can at least eliminate LabWindows/CVI from the equation.
Applications Engineering
(2,999 Views)
Thanks, Daniel.  Problem solved by using their dynamic (uses libMPSSE.dll) sample program instead of the static one.
(2,992 Views)
