LabWindows/CVI
FFT
In the discription of the advanced analysis lib function FFT(CVI 6.0) I do
not find any hint that the size of the sequence is a power of two.
Is it posible to use an other sequence size?
Babak
(3,146 Views)
Hello
You should be able to use a sequence of any size with the FFT function. However, using FFT on a sequence the size of a power of 2 will run alot faster.
Bilal Durrani
NI
Bilal Durrani
NI
(3,146 Views)
