06-21-2007 11:03 AM
06-25-2007
07:35 PM
- last edited on
02-03-2026
01:16 PM
by
Content Cleaner
Hello Andy,
Probably you typed your sample frequency wroong, unless you do want a good amount of aliasing (1.25mHz). Could it be 1.25MHz?
Now, I am not sure about the correlation you talk, I am not familiar probably (or collelation). Do you want the magnitude of the frequency domain or the power spectrum?
A couple of things if you read this article [broken link removed]:
- If you window, you are already reducing spectral lekage and therefore coherent sampling is not a must.
- If you sample at 1.25 MHz and get n*125 samples (n is an integer), you will get a multiple number of cycles of your 10 kHz signal so it will be coherent. You did not mention what is the other tone.
Finally, try to keep your questions on one forum so that future customers can find them in a centralized location.
