LabWindows/CVI
ExcelRpt_SetCellValue function to write to multiple cells
I'm not sure how to use the ExcelRpt_SetCellValue function to write to more than 1 cell at a time. The function panel specifies that a cell range can be selected so I presume that data can be written to more than 1 cell.
Hope you can help.
Cheers, Sandro
(4,587 Views)
the function call only writes to one cell. Even though it takes a range, the help for the range says the following :
The range of an individual cell. This value should be a string containing the cell range, such as "A1". If the range contains multiple cells, this function will examine the uppper leftmost cell in the range.
Instead, try the
ExcelRpt_WriteData (, "", ExRConst_dataDouble, , , );
function, which will take an array of 2D data (right click on items in the function panel for more information on what each parameter needs to take in.
(Function can be found under Excel Report->Cell Range->Write Data)
Hope that helps
Sacha Emery
National Instruments (UK)
// it takes almost no time to rate an answer Smiley Wink
(4,523 Views)
Thanks!
(4,517 Views)
Hi, was trying the ExcelRpt_writeData function but can't seem to get it working.
After starting an excel application, workbook,.. etc
I write: EXcelRpt_WriteData(worksheetHandle, "A1:A2", ExRConst_dataDouble, 1, 2, data)
where data = {100,101}
I keep getting runtime errors Could you show me an example please.
Thanks, sandro
(4,519 Views)
what are the runtime errors???
I have Windows XP, CVI 7.1 and according to the help->about Excel 2002 sp-1.
I've pasted in below an example which works for me (note the order of the rows versus columns - Dealing in one column, so that's 2,1 for the dimension sizes:
#include
#include "excelreport.h"
int main (int argc, char *argv[])
CAObjHandle HdlWorkbook;
CAObjHandle HdlXLApp;
CAObjHandle HdlWorksheet;
double data[2] = {200,2354.25898};
if (InitCVIRTE (0, argv, 0) == 0)
return -1; /* out of memory */
// Open Excel and make it visible
ExcelRpt_ApplicationNew (VTRUE, &HdlXLApp);
// Get a New workbook
ExcelRpt_WorkbookNew (HdlXLApp, &HdlWorkbook);
// Get the first worksheet (could get by name here if necessary
ExcelRpt_GetWorksheetFromIndex (HdlWorkbook, 1, &HdlWorksheet);
// put a breakpoint in here
ExcelRpt_WriteData (HdlWorksheet, "A1:A2", ExRConst_dataDouble, 2, 1,
data);
// close workbook
ExcelRpt_WorkbookClose (HdlWorkbook, 0);
// Quit Application
ExcelRpt_ApplicationQuit (HdlXLApp);
// tidy up memory space
CA_DiscardObjHandle(HdlWorksheet);
CA_DiscardObjHandle(HdlWorkbook);
CA_DiscardObjHandle(HdlXLApp);
return 0;
Hope that helps
Sacha.
(4,505 Views)
Used your method and all was good! Think I was going wrong with the datatype.
Thank you very much for your help,
Sandro
(4,501 Views)
