LabWindows/CVI
Excel ActiveX Control compatibility principles?
Hello Ian,
Well you probably will get more consistent behavior if you create a distribution kit including your application and the ActiveX control.  Then you should choose to register your controls as ActiveX servers on the Create Distribution Kit dialog window.  Then if you distribute this kit to your other machine, you should get more consistent behavior because you should be assured having the same version of the control on each computer.
Wendy L
LabWindows/CVI Developer Newsletter
Message 11 of 11
(854 Views)
