LabWindows/CVI
Excel ActiveX Control Manual
Does anyone knows where can I find a manual for the Excel ActiveX Control ? I am reading the samples provided with the CVI Compiler but cannot find a manual that documents how each function works.
Thanks.
(4,660 Views)
Pacsoft,
since the functions of the activex-controls are provided by the appropriate activex-server, documentation for the functions has to be distributed by the creator of the server. in the case of excel, this would be microsoft. you can find infos on the activex-interface of excel on msdn.microsoft.com. microsoft also releases informations about their interfaces via "microsoft press". you can take a look here.
another trick to get infos about the functions and their parameters is to use "macro-recording" in excel. this creates vbs (visual basic scripts) which use the same functions as exported by the activex-server.
hope this helps!
Norbert B.
Message Edited by Norbert B on 09-22-2005 05:56 AM
Norbert
Expert: Geometry
(4,643 Views)
Ok. Thanks.
(4,621 Views)
Hi there !
I'd like to know if you have found the manual Pacsoft, because I have searched, but there is not a lot information....
It could be great if you got it.
(4,412 Views)
You might like to look here.
Martin
Certified CVI Developer
(4,398 Views)
Thanks a lot.
I have spent a lot of time to search this kind of information, but there website is a bit complex.
(4,393 Views)
