LabWindows/CVI
Example of ConnectToTCPServer function's void *callbackData parameter?
I am trying to use the ConnectToTCPServer function's void *callbackData parameter as a method of determining which of several tcpip servers has reponded to my client.
I am using the function as shown below:
 had_err = ConnectToTCPServer(&interface[portid].tcpip_handle,
        interface[portid].socket,
        interface[portid].ip_address,
        Net2SerialCallback,
        (void *) &test,
        //(void *) &portid,
        interface[portid].timeout_msec
And my call back function is something like below:
int CVICALLBACK Net2SerialCallback (unsigned handle, int event, int error, void *callbackData)
    //I
(4,479 Views)
Sorry, the post was sent before I had finished it.
I am trying to use the "void *callbackData" parameter to hold the value that was passed in that parameter in ConnectToTCPServer.
I have not been successful.  It appears that callbackData always contains the same values (junk?) no matter what value I pass in ConnectToTCPServer.
Has anyone ever successfully used the callbackData parameter?
(4,478 Views)
You need to make sure that your variable test is not a local variable. Because if it is, then the address that you're storing in the callback data is just a stack address that will become invalid as soon as the function in which you connected to the server exits.
If you're already using a global variable, then let me know, and we'll see if we can investigate further.
Luis
(4,459 Views)
Thanks Luis.  You are correct.  My normal variable is global, but the test variable I experimented with was not.  That took care of my problem.
Thank you very much.  I appreciate your help.
(4,453 Views)
