LabWindows/CVI
Example finder Launches Labview VI menu dialogue
I am trying to use the sample finder from the Help>Find Examples menu in CVI 7.1. When I select the menu entry CVI launches a Labview VI dialogue box instead of showing the sample finder application.
The executabe properties seems fine:
"C:\Program Files\National Instruments\Shared\Example Finder\1.0\bin\NIExampleFinder.exe" -- cvi 7.1 locale,en
Any ideas?
Jattie van der Linde
Engineering Manager, Software & Automation
TEL Magnetic Solutions Ltd
(3,196 Views)
Jattie,
Does this also happen if you run the example finder directly -- from the path that you are showing below -- or only if you launch it from CVI?
Luis
NI
(3,184 Views)
It Happend all the time. I resolved it by uninstalling CVI and re-installing and it now works properly again. Thanks
(3,159 Views)
