LabWindows/CVI
Event Counter
I have a system requirement to determine if an event has occurred 5 or more times in the last hour.  This event occurs when input signal conditions logic goes true.  This would imply that there is a mechanism to record events on a queue and remove them when they become more than 1 hour old.  Unfortunately, I think in C++ style of programming and want to use a structure.  Given that LV is a signal flow description, maybe there is a lean and elegant block to handle this task?   The more likely answer is that there are a combination of other blocks and that I must learn change the way I think.
Constructive and actionable guidance is appreciated.  An example would be ideal.  Thank you.
(3,088 Views)
Do you want to solve this problem in C or using LabVIEW? Some of the terms in your post suggest the latter, in this case you might get better response in the LabVIEW forum.
(3,082 Views)
