LabWindows/CVI
Error while compiling
I am working in LabWindows 8.0.
I am making an application which will interact with Digital Multimeter HP34410.
I downloaded IVI driver from the site and using the same.
But While compiling I am getting following Errors.
AV900_SATS.prj(Release) - 68 link errors
Undefined symbol '_Ivi_GetAttributeViReal64@20' referenced in "hp34401a.c".
Undefined symbol '_Ivi_SetAttributeViSession@20' referenced in "hp34401a.c".
Undefined symbol '_Ivi_ResetInterchangeCheck@4' referenced in "hp34401a.c".
Undefined symbol '_Ivi_GetViInt32EntryFromString@28' referenced in "hp34401a.c".
Undefined symbol '_Ivi_SetAttrRangeTableCallback@12' referenced in "hp34401a.c".
Undefined symbol '_Ivi_GetViReal64EntryFromCoercedVal@32' referenced in "hp34401a.c".
Undefined symbol '_Ivi_AddAttributeViInt32@32' referenced in "hp34401a.c".
Undefined symbol '_Ivi_GetAttributeViString@24' referenced in "hp34401a.c".
Undefined symbol '_Ivi_SetAttributeViAddr@20' referenced in "hp34401a.c".
Undefined symbol '_Ivi_GetViReal64Type@12' referenced in "hp34401a.c".
Undefined symbol '_Ivi_viWrite@16' referenced in "hp34401a.c".
Undefined symbol '_Ivi_DefaultCheckCallbackViInt32@16' referenced in "hp34401a.c".
Undefined symbol '_Ivi_SetErrorInfo@20' referenced in "hp34401a.c".
Undefined symbol '_Ivi_viRead@16' referenced in "hp34401a.c".
Undefined symbol '_Ivi_GetPtrToSpecialViReal64Value@4' referenced in "hp34401a.c".
Undefined symbol '_Ivi_GetAttributeViBoolean@20' referenced in "hp34401a.c".
Undefined symbol '_Ivi_CheckAttributeViInt32@20' referenced in "hp34401a.c".
Undefined symbol '_Ivi_AddAttributeViReal64@40' referenced in "hp34401a.c".
Undefined symbol '_Ivi_GetInfoFromResourceName@20' referenced in "hp34401a.c".
Undefined symbol '_IviDmm_InterchangeCheck@8' referenced in "hp34401a.c".
Undefined symbol '_Ivi_GetErrorInfo@16' referenced in "hp34401a.c".
Undefined symbol '_Ivi_SetAttrReadCallbackViString@12' referenced in "hp34401a.c".
Undefined symbol '_Ivi_ParamPositionError@4' referenced in "hp34401a.c".
Undefined symbol '_Ivi_GetAttributeViSession@20' referenced in "hp34401a.c".
Undefined symbol '_Ivi_SetStoredRangeTablePtr@12' referenced in "hp34401a.c".
Undefined symbol '_Ivi_AddAttributeViString@28' referenced in "hp34401a.c".
Undefined symbol '_Ivi_ClearErrorInfo@4' referenced in "hp34401a.c".
Undefined symbol '_Ivi_CheckAttributeViReal64@24' referenced in "hp34401a.c".
Undefined symbol '_Ivi_GetAttributeFlags@12' referenced in "hp34401a.c".
Undefined symbol '_Ivi_IOSession@4' referenced in "hp34401a.c".
Undefined symbol '_Ivi_Dispose@4' referenced in "hp34401a.c".
Undefined symbol '_Ivi_GetNthChannelString@12' referenced in "hp34401a.c".
Undefined symbol '_Ivi_LockSession@8' referenced in "hp34401a.c".
Undefined symbol '_Ivi_SpecificDriverNew@12' referenced in "hp34401a.c".
Undefined symbol '_Ivi_AddAttributeViBoolean@28' referenced in "hp34401a.c".
Undefined symbol '_Ivi_DefaultCheckCallbackViReal64@20' referenced in "hp34401a.c".
Undefined symbol '_Ivi_CheckAttributeViString@20' referenced in "hp34401a.c".
Undefined symbol '_Ivi_SetValInStringCallback@12' referenced in "hp34401a.c".
Undefined symbol '_Ivi_SetAttributeFlags@12' referenced in "hp34401a.c".
Undefined symbol '_Ivi_QueryInstrStatus@4' referenced in "hp34401a.c".
Undefined symbol '_Ivi_UnlockSession@8' referenced in "hp34401a.c".
Undefined symbol '_Ivi_GetAttrRangeTable@16' referenced in "hp34401a.c".
Undefined symbol '_Ivi_ApplyDefaultSetup@4' referenced in "hp34401a.c".
Undefined symbol '_Ivi_InvalidateAttribute@12' referenced in "hp34401a.c".
Undefined symbol '_Ivi_CheckAttributeViBoolean@20' referenced in "hp34401a.c".
Undefined symbol '_Ivi_Simulating@4' referenced in "hp34401a.c".
Undefined symbol '_Ivi_SetAttributeViInt32@20' referenced in "hp34401a.c".
Undefined symbol '_Ivi_WriteInstrData@8' referenced in "hp34401a.c".
Undefined symbol '_Ivi_InvalidateAllAttributes@4' referenced in "hp34401a.c".
Undefined symbol '_Ivi_CheckAttributeViSession@20' referenced in "hp34401a.c".
Undefined symbol '_Ivi_SetAttributeViReal64@24' referenced in "hp34401a.c".
Undefined symbol '_Ivi_GetSpecificDriverStatusDesc@16' referenced in "hp34401a.c".
Undefined symbol '_Ivi_BuildChannelTable@16' referenced in "hp34401a.c".
Undefined symbol '_Ivi_ReadInstrData@16' referenced in "hp34401a.c".
Undefined symbol '_Ivi_GetNextInterchangeCheckString@12' referenced in "hp34401a.c".
Undefined symbol '_Ivi_SetAttrCoerceCallbackViReal64@12' referenced in "hp34401a.c".
Undefined symbol '_Ivi_AddAttributeInvalidation@16' referenced in "hp34401a.c".
Undefined symbol '_Ivi_SetAttrCheckCallbackViInt32@12' referenced in "hp34401a.c".
Undefined symbol '_Ivi_SetAttributeViString@20' referenced in "hp34401a.c".
Undefined symbol '_Ivi_NeedToCheckStatus@4' referenced in "hp34401a.c".
Undefined symbol '_Ivi_DeleteAttribute@8' referenced in "hp34401a.c".
Undefined symbol '_Ivi_GetNextCoercionString@12' referenced in "hp34401a.c".
Undefined symbol '_Ivi_GetAttributeViInt32@20' referenced in "hp34401a.c".
Undefined symbol '_Ivi_GetViInt32EntryFromValue@32' referenced in "hp34401a.c".
Undefined symbol '_Ivi_ClearInterchangeWarnings@4' referenced in "hp34401a.c".
Undefined symbol '_Ivi_SetAttributeViBoolean@20' referenced in "hp34401a.c".
Undefined symbol '_Ivi_SetAttrCheckCallbackViReal64@12' referenced in "hp34401a.c".
Undefined symbol '_Ivi_SetNeedToCheckStatus@8' referenced in "hp34401a.c".
(2,351 Views)
Is your system up to date? The driver page tells that you must have specific minimum versions for IVI Compliance package and NI-Visa: can you check your system?
Also, it declares the driver for CVI8.5: I haven't used that driver so I'm not sure it will work on 8.0
(2,296 Views)
