LabWindows/CVI
Error at application installation
I am trying to make a distribuation disk for an old project with a CVI 2012 version but i can't get it to work.
I can run the application in debug mode and even make the distribution kit without errors but
when i try to install i get the error massage ".\distribution.cpp(5890):installer error 10011
Fatal error value out of range <no debug imformation>"
Where can i found the value that feil??.
Best regards
Eugen
(3,361 Views)
This error has been reported a few times in the past and was solved by one of the following two solutions:
  1. The project build may be in a bad state. Delete the cvibuild.<projectname> directory and then rebuild your project and distribution.
  2. What do you have set for the "Distribution media size" option in the Advanced tab of the Edit Installer dialog? Is this size smaller than your distribution (including items selected in the Drivers and Components tab)?
(3,342 Views)
Thank you for four reply the problem seems to be solved by deleting the "cvibuild" catalog.
Regards
Eugen
(3,336 Views)
