LabWindows/CVI
Error 3005 occurred at Automation Open: Object specified is not creatable
I was able to integrate Google Earth Application in labview successfully. And am also able to access its features. Now I want to create a polygon or a point at certain position on the map. But I am facing problem with the portion of code I am attaching in this post.
Its Giving Error in Automation Open. I have no clue what's wrong with it.
Help needed.
Any reading material, or quick help will be really appreciated .
Regards.
(3,154 Views)
you've chosen the wrong forum - this one is dedicated to LabWindows/CVI. You should repost your question in the LabVIEW forum here: http://forums.ni.com/t5/LabVIEW/bd-p/170
(3,147 Views)
thanks for your reply... i don't know much about the forum.
(3,143 Views)
