LabWindows/CVI
Editing TestStand userlist form CVI whitout running a TestStand sequence
I am using CVI to create an own User Interface based on TestStand 2.0. I can insert new users and check them passwords and login names, but I can edit user's passwords. I have tried to use TestStand API fuctions ("TS_PropertyDisplayPropertiesDialog" and "TS_EngineDisplayEditUserDialog") to modify userList. Program loads those "Edit Users" dialog boxes but user's properties can't be modified. Are those properties "read only" ? Is it possible to edit user's password and properties without using a "TS_SeqContextGetProperty" ? My Operator Interface is not executed from TestStand by running a sequence instead it is executed from CVI. This is the reason why I don't get any sequence context references for th
e user properties edition. Thanks for your help!
(3,068 Views)
This question should be posted in the TestStand Forum
(3,068 Views)
So you are seeing behavior where in CVI you are creating a new engine, and then you use this engine to summon the EditUserDialog, however you are seeing all the fields in the new display are 'read' only? I think this problem is solvable simply by making sure to 'login' an administrator-level User prior to opening the dialog. For Example, if you use the functions TS_NewEngine(), TS_EngineGetUser(),TS_EngineSetProperty() before calling TS_EngineDisplayEditUserDialog (), and use them to acquire a handle to administrator and set TS_CurrentUser = administrator. Once TestStand has a user with appropriate permissions logged in, you should see that the fields in your Edit Dialog are now active and you can set new passwords etc.
If you are building a custom CVI operator int
erface, you will likely need this user-login behavior by default, so just make sure to include it in your code prior to any operations in the TS environment.
Elaine R.
Applications Engineering
http://www.ni.com/ask
(3,068 Views)
