LabWindows/CVI
EVENT_TIMER_TICK occurs sometimes while timer is getting enabled
I have a timer that is initially desactivated. When i activate this timer (timerstart), sometimes i have EVENT_TIMER_TICK that is fired (ModemTimeoutDnx == 10 for example). It works normally on some PC and sometimes it fails on other.
Any idea of this problem ?
Regards.
Christophe P.
void timerstart(int panel)
    SetCtrlAttribute(panel ,CONNECT_TIMERDNXAUTO, ATTR_INTERVAL , (double)(ModemTimeoutDnx*60));
    SetCtrlAttribute(panel, CONNECT_TIMERDNXAUTO, ATTR_ENABLED , 1);
void timerstop(void)
    SetCtrlAttribute( panel, CONNECT_TIMERDNXAUTO, ATTR_ENABLED , 0);
void timerreset(void)
    ResetTimer(panel,CONNECT_TIMERDNXAUTO);
(5,408 Views)
Hi Christophe,
I have tried, but I haven't found much about your issue. The only think I could think of would be a bug in your CVI version. can you tell me which version you are using? Can you be sure to have all the updates and patches installed?
Have a nice day,
M-Junior
(5,354 Views)
Hi M-Junior,
Thanks for your reply. I modify my source code to be sure that ModemTimeoutDnx is different from 0. I'm waiting somes tests from my customer.
Regards.
Christophe P.
(5,310 Views)
