LabWindows/CVI
EVENT_COMMIT when EVENT_CLOSE closing panel
    I have a string control in HOT mode with a callback associated with it.  If the cursor is on the control and I QuitUserInterface on the EVENT_CLOSE of the panel callback, the string control callback receives an EVENT_COMMIT.  I don't understand why this is happening any Ideas?  Do I need to remove the callback in the panel EVENT_CLOSE by setting the ATTR_CALLBACK_FUNCTION_POINTER to 0 or settting the mode to NORMAL?  I have never run into this before.
Mike
(3,676 Views)
can you post your string control callback...?
(3,665 Views)
If you are editing the string in the control it seems not strange to me. It happens the same when you operate another control during editing (e.g. type some characters in the string control and next click on a button): the string control receives the commit and lost focus events, next the new control receives the got focus and other possible events.
(3,649 Views)
Roberto is right, as usual Smiley Happy
While I was aware of the LOST_FOCUS event I didn't realize that this will also trigger a COMMIT event because changing the focus will also finish the text input.
(3,639 Views)
I didn't enter anything in, but the cursor was in the box before I hit the close button.  I ended up just disabling the callback before the QuitUserInterface.  Below is the code for the string callback and the panel callback.
Mike
int CVICALLBACK cbkTraveler (int panel, int control, int event,
        void *callbackData, int eventData1, int eventData2)
{ // cbkTraveler
    int    iRet;
    switch (event)
    { // Switch Event
        case EVENT_COMMIT:
            iRet = Message_Box("Database Access","Retrieving S/N's");
            iRet = Message_Box("Load","Load Parts");
            iRet = Message_Box("Marking","Marking");
            iRet = Message_Box("Un Load","Remove Parts");
            iRet = Message_Box("Verify","Are Parts OK");
            break; // EVENT_COMMIT
        case EVENT_LEFT_CLICK:
            break; // EVENT_LEFT_CLICK
        case EVENT_LEFT_DOUBLE_CLICK:
            break; // EVENT_LEFT_DOUBLE_CLICK
    }  // Switch Event
    return 0;
} // cbkTraveler
int CVICALLBACK cbkMainPnl (int panel, int event, void *callbackData,
{ // cbkMainPnl
    switch (event)
    { // Switch Event
        case EVENT_GOT_FOCUS:
            break; // EVENT_GOT_FOCUS
        case EVENT_LOST_FOCUS:
            break; // EVENT_LOST_FOCUS
        case EVENT_CLOSE:
            SetCtrlAttribute(panel, PNL_MAIN_TXT_TRAVELER, ATTR_CALLBACK_FUNCTION_POINTER, 0);
            QuitUserInterface(0);
            break; // EVENT_CLOSE
    } // Switch Event
    return 0;
} // cbkMainPnl
(3,628 Views)
