I have an unusual problem that I'm hoping someone else has seen. When I do an IVI initialize function on an E4436B I receive this error: Channel or repeated capability name specified is not valid for the instrument. I use the same code everyday on an E4437B, and I've also tried it on an E4438C without any problems. I've downloaded the latest IVI driver for the ESG models and I've downloaded Agilent's latest firmware into the E4436B, and I've had no luck. If I send the E4436B regular SCPI commands it works fine, but it doesn't like the IVI initialize function so I can't use it in my setup.
Has anyone seen anything like this? Thanks for your help!
