LabWindows/CVI
Does Labwindows support Vector CAN?
(3,772 Views)
Hey ramprasad,
Thank you for contacting National Instruments.  Unfortunately, Labwindows does not offically support Vector CAN.  The same thing goes for Labview as well.  However, Vector does provide a CAN driver that allows you to communicate with Vector CAN hardware while using Labview.  Information regarding this can be found in this knowledge base.  I would suggest contacting Vector to see if they made a similar driver for Labwindows.
Jason W.
Application Engineer
(3,752 Views)
Hi Jason
Thanks for the info. Hope we can use NI CAN instead of Vector CAN. We are planning to use the LabWindows for automating our test process. We have some sensors and switches as inputs to our module. We want to automate these inputs also. Can you suggest some points how to proceed and which digital and analog I/O cards we can use?
regards
ramprasad.
(3,725 Views)
Hey ramprasad,
Just to clarify, are you talking about DAQ cards or CAN cards?  If you are talking about CAN cards you can go here for a list of our CAN devices.  Just select your interface.  If you are talking about DAQ you can go here for a list of products.
Jason W
(3,695 Views)
