LabWindows/CVI
Does LabWindows/CVI support SNMP?
An audio/digital switch I am working with can be controlled by an operator via server software. This server has a MIB, and the associated switch can be queried and controlled by sending the Object IDs to the Server via SNMP. I want to control the switch from my LabWindows/CVI application. Does LabWindows/CVI support SNMP?
(3,520 Views)
Hello KenH,
LabWindows/CVI 7.1 support SNMP: Simple Network Management Protocol with the Windows SDK that ships with the Full Development System. After installing CVI, you will have the required include/lib files in the \sdk folder. Also, I would suggest taking a look at the help documentation (snmp.chm) and the document entitled "Notes on SNMP Development for Windows/NT" (snmp.txt).
Hope that helps.
Wendy L
LabWindows/CVI Developer Newsletter
(3,511 Views)
