LabWindows/CVI
Documentation Tags for Source Code:sugestion
Starting with version 8.0 CVI has the possibility to add documentation for function prototypes.
My suggestion is  that CVI  should look also for these tags also in a definition file (.h) not only in a source file(.c).
I think  it can be helpfull i'm already using a documentation code tool and i want to use also the CVI tags separately.
(3,257 Views)
Hello Danut,
it might be usefull to write this suggestion down in the NI product suggestion center:
http://digital.ni.com/applications/psc.nsf/default?OpenForm&temp1=&node=
(3,254 Views)
I post it over there.
Thank you for the link.
(3,243 Views)
