LabWindows/CVI
Distribution without drivers CD
I'm trying to create a distribution kit for use on a computer that does not have the labwindows CVI run-time engine. The distribution kit creater is asking for a National Instruments Device Drivers CD. Is there a way to not have this pop-up everytime and have the program get the drivers from the HD.
(3,268 Views)
Hi Nickeli,
You should notice a checkbox on that popup prompt that allows you to locally cache all the products that are required from that cd.  Note that this does not copy everything from the driver cd to your hard drive, just whatever is needed for that particular build.  In the future, if you select additional products for inclusion in your distribution, you may be prompted for the cd again.
Mert A.
(3,262 Views)
