LabWindows/CVI
Distribution kit calling 32Bit or 64Bit executable
my CVI app distribution calls an executable that installs a hardware driver. Unfortunately, that executable (DPInst.exe) has separate versions for 32bit and 64bit OSs.
Question:
can the distribution kit (CVI 2009) be configured to call e.g.
  •  "DPInst32.exe" when my app gets installed on a32bBit system, and
  •  "DPInst64.exe" on a 64bit system?
or
What would be an other solution for that kind of problem?
Greg
(3,466 Views)
Hi Greg,
That is a reasonable request, but from my user experiences I guess it is not possible or feasible.
Every driver or professional software packages I can think of separate their 32 and 64 bit installations.
So the user must be aware of the OS he/she is using and use the correct installation file.
Can you think of any contrary examples?
S. Eren BALCI
IMESTEK
(3,446 Views)
Hello Eren,
thanks for you feedback. I don't want to distribute and maintain different versions for 32bit and 64 bit OS of my CVI application, just because a small USB driver of an accessory has two versions. In the meantime, I came up with a different idea.
The distribution calls an executable that
a) checks wether it runs on a 32bit or 64bit OS
b) then calls the correct DPInst.exe version
This is quite easy:
I'm using this  example code to check the OS version.
with that I call this code at the end of the installation:
void main()
 char path[512];
 int status;
 status = GetDir (path);
    if(IsWow64()) strcat(path,"\\64bit\\");
     else  strcat(path,"\\32bit\\");
 status = SetDir(path);
 LaunchExecutable ("DPInst.exe");
void main()
char path[512];
int status;
This should do the trick.
Best Regards,
Greg
(3,427 Views)
