LabWindows/CVI
Distribution Setup Installation Fail
Yes, as I mentioned the application runs smoothly once you restart the computer after the fail message. My problem is, the installation is installing the "later" version of system configuration API, and then trying to reinstall an older version of itself. Because of this, the installation says that it fails at the very end. This is tacky and I do not want to give this to customers like this so I wanted to figure out where and why my installation is installing this driver twice.
Message 11 of 12
(2,012 Views)
If you remove VISA from your distribution do you still get this error?
Like I said before, you might consider letting your clients install the drivers themselves considering that they might already have a newer version of MAX on their PC.
https://www.linkedin.com/in/trentweaver
Message 12 of 12
(1,983 Views)
